whifof100ll
I have recently realized that the bolts attaching my FAB to the vertical fuel injection are not saftied. Van's has a service bullitin (96-10-1) that I am not in compliace with.
I took the attaching hardware into the shop to attempt to drill the heads, but after taking as much care as I can muster, I have busted off two bits in the two bolt heads and cannot get them out.
These are 1/4x20 bolts 1/2 inch long. Have others been able to get these with drilled heads and what are good sources? They also discuss using locking tab washers instead of safty wire.
What are good sources of supply for these?
