647jc
I recently bought several pieces of 6061 aluminum angle stock from ACS of different sizes, ??, 1?, 1 ?? and 2? all 1/8? thick. I had cut a 7? piece from the 1 ?? stock and was in the process of ripping one flange down to 1 1/8? on my band saw. I had already ripped the other flange down to 1? with no problems. While ripping the other flange to 1 1/8?, about 1? from the end of the piece the band saw just stopped cutting, even with quite a bit of pressure it would not cut anymore. I removed the aluminum angle and tried to cut another piece of aluminum and same thing, the blade was completely dulled. So, I replaced the blade and tried cutting a different piece of aluminum and it cut fine. I then went back to the piece of angle I was trying to rip and was able to cut about 1/8? further and then the blade was completely dulled again, ruined!
It appears there is a ?hard spot? in the aluminum angle that instantly dulls my band saw blade whenever I try to cut through the area. I?ve never had this happen before but after searching a bit on the internet I found documentation of this happening on different cast aluminum products. Apparently some manufactures mix some scrap aluminum in with their new melt and if there are any iron borings in the scrap, it can cause these hard spots in the casting. So, apparently the 6061aluminum angle I just got from ACS has some scrap aluminum with iron borings in it. This is all kind of interesting but unfortunately I?ve now destroyed 2 good band saw blades. Hopefully I won?t be running into any more of these ?hard spots?.
