I'm building a barn/hay shed/hangar 38' x 48' with 12' eave. Post Frame
construction with 38', 4/12 pitch, clear span wood trusses. Leaving a
30' opening on the east gable end. Would like to build a bi-fold
door in this 30' opening.
I build a lot of rolling doors for the company I work for using steel girts, rib metal and bottom and side rails. Would like to use these materials if possible.
Any suggestions, plan references or help would be appreciated.
Hopefully an RV-3 will be born in this stable.
