The cold engine pre-start was completed, key to start but the prop barley moved on several attempts. Low battery charge. With brakes held and switch OFF, Co-Pilot pulled the prop through several times from front of aircraft. With key to both, brakes held and Co-pilot BEHIND the prop, the prop was pulled downward and immediately started. If you get stuck, Its worth a try!
