If you were building a slider instead of a tip-up, you could install handles similar to the ones on my RV-6. They are a great feature for helping to hoist yourself up out of the seat.!!
It would be a real bummer to hit your head on one of those handles in an emergency. If you are going to use them, I'd recommend installing them as parallel to the slider portion of the canopy as possible.Neal can you give specifics on the handles? Where bought, how attach, etc? Thanks a bunch!!
I've found that handles really aren't necessary if you grab (with your inboard hand) on the underside of the roll bar while climbing over the fuselage side and then shift your grip to the roll bar brace as you slide down into the seat. Reverse the order getting out.
