KatanaPilot
One of my concerns about the hall sensor wiring on our SDS equipped RV-10 is a belt break damaging the wiring. Don’t really know if it’s a valid concern and in my case I have two belts.
I have prototyped a shield for the wires attached to the hall sensor attach bracket. SDS provides threaded mounting holes just for this purpose.
I am looking for additional ideas from anyone who has addressed this concern on their installation to see if I’m on the right track or if someone has a genius idea they wouldn’t mind my copying.
If you prefer not to post here or find it cumbersome to post pictures, please email me. Krea dot Ellis at gmail dot com
Thanks!
Protection done easy
Some people are going to ask. What do you so for an 0-360 four banger? Here's mine. Simple angle bolted on.
Art
IO-540
So easy, many versions.
Mine was a simple shield mounted on the provided SDS crank sensor pad with the wires protected in fuel tubing .
Tip: slightly squeeze the fuel tubing into on oval shape and the wires pull through effortlessly.
ACtC-3cZ5p17V5Z0bVLzLBt6okaMGrq03k5D036rtJrR3PCah650FRONiKLNHLqexJGcKirns2V7BOGQ0KgLgEnkK3TVst-fCJtEBSsaWjjXfczxw3sIbzZ8oLHhykFX4R8UWCyLQOmm11KYGVvPAHOdDkKZ=w678-h903
ACtC-3d-ikXswIAnJxclL-0sHOIV3SePovJniTZAsY9l4yK1FYxz4mMNnePPMtza8xYPoyqwuloEa7hrMjwqPIEVRpnEUZtkcwZ1sNdh6f1pE2bHFAz1Op2gCOFTB2hWR0IbxQLNvvC9CpqicSWIsaMIhXrg=w1204-h903
and on an IO-360 RV-7
ACtC-3fySA-qMya0x6ttzCGDw_EPTIEM5AxCHWY6_odFJDnOLYrbfRiLAMbdgdVMka7pySpQ1SWzm7tsownMxtKLf_OMZ82JYXCzp5Zw4B9gNzD21uysgGMr1-zHA64l341Pl2D9xxNh0O_l2GWIHRMYnjmCug=w678-h903
and on a IO-390 RV-14A
ACtC-3dyfRPISyYf489ehx_eTczc93a-bulDWh-3poJI1uZgHjIpov8pz7EBUMGS8V_TIaW09RgE-YPNphXa-volDYM0Ie7AmRnL9-zVXLosJBCv0pMD2HAkjsvFCKSJEUy0oqtSyi0maV-3ciaotDFlg9665A=w418-h903
