David-aviator
To quote Rod Schneider regarding the tear down of the Subaru H6 (3.0) engine core I gave him for that purpose,
"Hi, Dave,
Well, I finally got the engine taken apart this afternoon. I was waiting
for some tools I'd ordered to come in, and they arrived yesterday. There is
good news and bad news.
The good news is: I couldn't really find anything wrong inside at all.
The bad news is: I couldn't really find anything wrong inside at all........
The cylinders look fantastic and measure well within specs for taper and out
of round. There was just the slightest bit of a carbon ridge at the top of
the bores. The pistons and rings look equally good with no signs of any
deposits in the ring grooves or any hint of detonation damage to the ring
lands or piston surface. Piston ring end gaps are per spec in all six
cylinders. I discovered that the tan deposits in the combustion chambers
and on the tops of the pistons will scrap off very easily with a fingernail...."
The bad news here is we really do not know why the performance of the engine had dropped off earlier this year. Two items could be the cause since the 245-250 degree temperature excursion last summer appears to not have damaged the engine or be the cause.
1. The little bit of 100LL fuel used did leave some oxidized lead deposits which may have caused the low compression readings. Three cylinders were running below the 185 bottom limit on the last compression check in July.
2. The $1315 internal muffler I bought from Jan in March 08 could have caused a loss of power due to excessive back pressure. Jan had asked me to remove the muffler to see if it was the cause of the performance loss but I couldn't because the headers had been changed to accommodate the muffler. I simply ran out of patience with the matter and felt the muffler should have been flight tested to where it worked without loss of performance.
To summarize, this is good news for guys with this engine. Early on I had a conviction that it was a good tough little motor and so far the evidence would seem to support that early feeling. If anything we have reduced the list of causes for the drop in power.
Do I regret bailing out of Subaru? Considering the economic situation since the decision was made and these findings, I probably could have hung in there a little longer. But I am not one to look backward with regrets. There still are cooling and performance issues I remain weary of dealing with. Unlike Ironman Paul who turned the big 50 this week, I will turn the big 70 next February and feel a need to back down a bit if I am to continue flying.
The really good news here is the engine is not all that fragile and guys with it certainly can work on the cooling and performance issues with some confidence in the engine itself. The overall development has evolved with larger radiators and a dedicated cowl to make them work much better than the early versions.
One final note, the guy doing this tear down and inspection is a maintenance inspector with a major airline and knows his stuff. Rod says the engine is remarkably clean inside and so far all tolerance measurements are OK.
![](/community/proxy.php?image=http%3A%2F%2Fimg81.imageshack.us%2Fimg81%2F5470%2Fteardown1st1.jpg&hash=1166e474a11c63ff283e4696c5eedea3)
![](/community/proxy.php?image=http%3A%2F%2Fimg81.imageshack.us%2Fimg81%2Fteardown1st1.jpg%2F1%2Fw640.png&hash=d1471868d4aad0aaccfcc02ae6eacb25)
"Hi, Dave,
