D DMFenster Well Known Member Dec 31, 2014 #1 Will a DG that is not set-up for a tilted panel work in a 8? Dave DUES PAID
pierre smith Well Known Member Dec 31, 2014 #2 Dave, it's usually the artificial horizon that is set up for the tilted panel. Best,
cfiidon Well Known Member Dec 31, 2014 #3 Tilt I would imagine they would all work. After all, the -8 is tilted backward about 14 degrees when it's on the ground. Don
