GX Pilot Autopilot Starting Settings
The numbers Brian referred to are for a different configuration. For the GX Pilot, I received the following STARTING settings from G3X support, for those of you who need/want the same information.
LAT ACTIVITY - 3
LAT TORQUE - 12
BAUD RATE - determined by your GPS (in my case, 9600)
BANK ANGLE - MED
GPSS GAIN - 16
MICROACTIVITY - 0
YAW DAMPER - N, unless TruTrak yaw damper installed
PITCH AXIS - Y, if pitch servo installed
VRT ACTIVITY - 2
VRT TORQUE - 12
MIN AS - 65
MAX AS - 180
STATIC LAG - 0
MICROACTIVITY - 0
HALF STEP - N
