flickroll
I had a set of the new style Van's tips shipped to me last fall. Today finally got around to fitting them to my RV-8. This is a retrofit installation - I'm removing the original ones. So I mounted the tips, after primary trimming, using duct tape to hold them on initially (no helper...), and drilled all of the holes with a #40 bit, then drilled them again with a #30. Fabricated the aluminum strips for the nutplates on the inside of the tips with 0.025 2024 T3. Then, I scuff sanded the area where I wanted to bond the aluminum strips. Thats when I noticed the problem. The sandpaper was loading up with some sort of gummy stuff. Then I wiped down the sanded area with MEK, and the glass got even more sticky feeling. After that, I wiped it down with denatured alcohol and all seemed well (not sticky). I then bonded the aluminum strips with a epoxy/cabosil mix and called it a day.
When I got home I mentioned this to my son who is an ME student at VA Tech. He interned last summer with a company that manufactures industrial components using vinylester resins. He said send the tips back to Van's - they either have too much catalyst or not enough. That's not really a possibility - the shipping cost would be really expensive. Besides, the tips have gel coat on them and they seem structurally sound. So....to you expert glass guys out there. Is there a problem? Will I have problems in the future getting paint to stick? I think there will be no problem with the paint as the gel coat seems well bonded. Or, will the gel coat eventully fail? Or...don't worry about it? Or....?
