Rick_A
I keep playing with the User selected data fields on my GTN 750. I've never been able to get the one called "Tuned VOR" to display any data.
When I select Tuned VOR as a data field, I just get blanks in the "Radial" and "Distance" sub-fields. I never get any data. I have a valid VOR tuned in and the VOR identifier shows correctly. I also get the correct audio confirmation when I select NAV on the audio panel, so I know the VOR signal is being received correctly.
Wondering if anyone else has tried this data field and used it succesfully? Was there anything special you needed to do to get it to work?
