Acenels
Active Member
As the title suggests--has anyone been able to successfully connect a GTN 650 to an appareo for pressure altitude encoding vis RS-232?
Appareo has taken about 5 days per email to respond, and isn't exactly winning the customer support Olympics, so hoping someone here had figured this out (or can confirm it won't work).
I have the RS232 running through RS232 2 out on the GTN 650xi into pin 5 on the appareo. I have tried aviation 1 and 2 on the GTN, and each of the input selection options on the Appareo transponder to no avail.
I can't figure out which format works between the two, if any. My next step is to pull the harness apart and connect it directly to the G5 RS-232, and hope that will work if this won't, but thought I'd check in here first.
