Bavafa
Is there any specific configuration on GTN is needed for the TOGO button to function correctly? Looking at the install manual, if I understand it correctly, in the main system configuration we will need to change the Air/Ground Discrete to be set based on the position of the status of TOGO button (i.e. if it is normally open, it would need to be set to "Active for Ground"
currently, when I push the TOGO button, the GTN does not automatically execute to the Miss approach and I get a "suspend" or "miss approach" option which needs to be selected manually.
In the discreet set up, you have to select the connector/pin you wired the toga to to 'remote go around'.
Has nothing to do with air/ground input.
