TJCF16
I would like to see the Garnin guy's make a software change that allows the GTN625 to scroll automatically. The way it is now if you are doing an approach and you have several fix's the Magenta bracket moves to the next fix in your approach, and then the next, on and on till the final fix. However you have to manually press the down arrow to keep the magenta bracket in the window. On a busy approach it is nice to look over and see where you are headed. It needs to have the magenta bracket stay in view at all times.
