stneki
Patron
With the GRT SX controlling a Vizion 385 in heading mode I constantly get a wing rock and the stick is constantly moving. Looking for suggestions on how to adjust or make changes to the settings.
Is the plane trimmed correctly, I have a TruTrak ADI Pilot II. If it's out of trim it will constantly rock the wings.
I have same and no rocking.
Grab the 385 manual and in good VMC take out some Lateral Activity (0-24, higher, more active).
While flying, autopilot engaged, press and hold the mode button. The will put you in the config mode. The first selection is roll gain/lateral activity, turn the knob to the left until roll gain is zero and then exit. My rv6 does the same thing in perfectly still air. I adjusted the roll gain to zero and when it is slightly moving the stick, i roll in a little roll trim. This takes out the dead zone in the servo. Flys like it is on rails.
