Stein?
I'm going to weigh in here and hope that Stein will to. I had this same decision and asked him for the comparison - he basically told me the Sport is more bang for the buck than the Dynon solution
for my mission.
I want IFR "light". Save the lectures, I've heard 'em. I'll fly mostly VFR but with occasional IFR to penetrate a layer up or down. I'm in Southern AZ so the only IFR I'm likely to fly here is practice (IMC in AZ pretty much means stay on the ground), but I'll fly to California regularly and the marine layer there is my issue. I don't intend to plan for enroute IFR.
I want:
- dual axis autopilot
- dual screen efis (solo from right or left)
- IFR GPS
- TIS traffic (like to have, costs more)
- single panel comm
- single panel nav (vor/loc/gs)
- handheld backup GPS + XM weather (tied into panel)
- handheld backup comm (tied into panel)
That said, here are some of MY pros & cons:
- Dynon appears simpler (one stop shop for efis/ap/ems and one less box) and probably a tiny bit cheaper top to bottom
- GRT has moving map + HITS, can do TIS
- GRT wins for robustness/non-single source solution IMO (sep. EMS, diff brand independent autopilot, TruTrak in my case)
- AP is my AI backup and TruTrak has a stellar rep.
- GRT has a better / deeper upgrade path
- The EMS for GRT is butt ugly and takes up serious panel space, but can serve as a backup and is on instantly. I may bury it, I may not. Deciding is the downside here, with Dynon there are no hard choices to make
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- I am nervous that GRT's ARINC for the Sport doesn't seem to be out, but I may not be up-to-date on that.
Most other things
for me are a wash, including what I perceive to be excellent customer service & support from either.
Here is my RV-7 panel as currently planned, click for larger image:
Notes:
- this is Van's stock panel.
- that will be a Garmin 430W + Garmin 330 Xpdr + TruTrak DII VSGV (pic probably not 100% right)
- Garmin 496 on ball-mount movable to either side and still tied in (pic is a 396)
- plane to be setup for solo right or left, I'll solo right mostly
- sticks have PTT only
- Icom A6 + all Headset/Mic Jacks just aft of fuel valve
- LRI is homebrewed and totally electron free
- elevator trim tied into trim monitor, manual aileron trim
- all lighting switches on right side are off to the left, on to the right
- GRT EMS presently buried, I may try to integrate it, I may just put the alert light on the panel
I welcome discussion/comments.
George
