Jim P
So I have a GRT H1/ EIS system and I've been using printed power charts for cruise, but I'm finally getting around to making the GRT graphical engine display the correct data. I have some good data (I think) for the input to the power correction table, but I wanted to confirm how to set the data type in the Graphical Engine Display menu. Is that entered under Dial #3, and if so, what are folks using for the scale?
UPDATE: Got some info from GRT and the issue was the MAP setting further down in the menu. Swap the MAP setting from INTEGER to DIGITAL and the problem goes away and displays as expected. Dial #3 has nothing to do with the issue.
