I've been looking for an answer for approximately 2 hours and have found little to no help. The manual for the Safefly 2020 from GRT is honestly junk. It says a few contradicting things. First it says to directly wire the ADSB input to a high speed serial connection (The Mini has 2 open serial connections per the manual). The SafeFly installation claims to have serial port combiner functions, but it goes to say that the AP servos should be wired directly to the EFIS for latency concerns. So direct wire for AP servos, direct wire for ADSB input, then how does the combiner connect to the Mini X when all available serial ports are used?
My dilemma is this, On my Mini X I have serial 2 open In/Out (Serial 1 is used by the AP Servos), I need to use that for the ADSB in from the SafeFly, but then that leaves me no open serial ports for the SafeFly GPS input, serial combiner, and controller functions for the EchoUAT. Can anyone shed some light on this? GRT support has been difficult to get a hold of due to the reduced hours.
Scott
Scott
