RedRaider94
Active Member
Thought I would check with the GRT users out there. My HX screens are connected to my Garmin 430W and when I put a flight plan into the 430, it shows up perfectly on the moving map as a pink line.
Started my IFR training and was doing practice approaches. When I load and then activate the approach (GNAV OR ILS), the approach doesn’t show up on the map. Missed approach doesn’t either when I hit SUSP button on 430.
Is this normal or am I doing it wrong? I guess I assumed any white or pink lines on the 430 would always transfer to the GRT.
Thanks!
Thanks!
