Steve A
I am adding a Horizon HX to replace my Blue Mountain EFIS. I want to use the
HX as a CDI/glideslope and I was wondering if someone had a diagram for pin
placement. I look at the GRT Horizon HX diagram with inputs for CDI right/left, GSI up/down etc. Need a nice diagram to make sure I have it right.
Thanks.
S S Anderson
Lafayette, La.
RV-7A 255 hours
Serial in and Serial out
Kahuna,
I have the input and output from my SL-30 to my Blue Mountain that I am replacing. Since my BM never worked quit right and I did not have glide slope and CDI with that, I thought I could get that with the Horizon HX. The rear panel of the SL-30 has CDI R/L, GSI Up/Down, To FRom etc and the HOrizon had similar pin settings, I thought this is what I had to do to get a IFR VOR capacity. Thanks for the response.
S S Anderson
SL-30
Steve
This is how it is set up with my Skyview, should be the same if there is a serial port with the GRT HX
Just connect the SL30 serial to one of the SV serial ports 1 to 4. You need to set up the SL30 in its menu too.
SL30 37 dsub connector -
1 = pwr
2 = ground
3 = serial ground
4 = RX from SV ie (SV TX )
5 = TX to SV ie (SV RX)
& don't forget the audio --
23 = audio out (HI)
20 = audio ground (LO)
The SL-30 with the SV needs to be set to ''None', not resolver'' in the set up menu, I assume it must be the same with GRT..
This should take care of all the CDI/ GS set up..
Good Luck
Bruno
Bruno
Kahuna,
S S Anderson
You will only need the serial to interface the data you desire. The SL30 will feed the HX this through the serial data stream.
Bruno,Stein, Kahula,Thanks
As always I was making the problem too hard. The answer I was too dumb to
understand was the two wires carry all the info. I was trying to put ten wires
into my SL-30 behind the panel when the two wires already set up will suffice.
Thanks again all for helping out. This makes the set up much easier. I always look for the hard way to do it. At least I got online before tearing everything apart. Now hopefully I can be back in the air with the good weather.
S S Anderson
