RV-ers,
I recently purchased a RV-8 with two GRT Horizon Series I WS displays. I generally fly with the PFD on the top and Engine Display on the bottom screen. The engine information on the Horizon is fed through a the GRT EIS system.
On two flights, I noticed the EGT and CHT values were "Frozen" as in they wouldn't change. On one flight we were an hour and a half in at 12.5k and the values were frozen at the previous cruise power settings. On a recent flight practicing touch and go's I noticed the same issue but the values were stuck somewhere around a taxi setting or just after takeoff.
I called GRT and they haven't seen this issue previously. Next time I see this, I will verify if the EIS values are frozen as well. I've only noticed it on the Horizon GRT and didn't think to check the EIS values. I reloaded the software on the top and bottom Horizon's yesterday and will check them on the next flight.
Has anyone seen this type of issue? If so, what was the fix?
