Mike S
Senior Curmudgeon
I just wanted to let folks know about a "Gottcha" that has been driving me a bit crazy for a while now.
When I discovered the tach signal from the Slick "Laser" ignition box was not compatible with my GRT EIS, I decided to install one of the transducer that Vans sells, Part Number = IE VTACHGEN 12, so the tach signal would be forever separate from the ignition, should the Laser ever fail---make that "when".
The transducer that I got generates 8 pulses per revolution, and after conversation with GRT, I set the EIS to 8 P/R as per their advice.
The tach was reading an absolute max of 1350 RPM at full throttle, and low prop pitch, which seemed to be half of what it should be.
Late last night, it hit me, the tach drive off the rear of the engine------I'll bet it runs at the same speed as the mags, which are right next to the tach output.
A quick phone call to Mattituck, and Mahlon, and suspicion confirmed----the transducer was only going half of the crank RPM.
So, instead of getting 8 pulses per engine revolution, the EIS was only getting half of them, or 4 pulses.
Now, I have to go reset the EIS to a P/R of 4, and all should be golden.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
