fredbauerjr
We are setting up the "percent of horsepower being used" option on a friends EFIS SPORT HS.
Is there anyone out there in cyberland who has set up this function in their Sport HS unit?
We expect Lycoming has a chart showing various Manifold Pressure/ RPM readings for multiple horsepower outputs but we were hoping someone already has taken the time and effort to convert this data so it can be filled into the SPORT EFIS setup table.
We also understand that there needs to be correct interpretation of "horsepower" and "% of horsepower".
The Lycoming engine we need the settings for is the: O-320-D2B @ 150 HP.
Check out the files section of the GRT Yahoo group - that engine might have the data listed. If not, then give Sandy a call at GRT - she has tables for most popular engines.
Paul
Thanks Paul,
We did call GRT (Sandy) and she sent us the % of horsepower tables for Lycoming engines. We loaded the information into the EFIS SPORT tables and have the % power function set up.
