Don
I'm finally getting to the point where I'm wiring my panel. One by one I'm knocking out decisions about what options I'll use on the equipment I have purchased. I'm installing roll and pitch servos for the GRT AP. At this point I plan to wire one switch to turn both servos on or off. I have the option of installing momentary switches to engage or disengage each servo individually. I'm leaning toward not using this feature mainly because I can't think of when you'd want to only use one axis.
I realize this is probably just a matter of opinion but I'd like to hear if others think there's a good reason for adding these two switches. At this stage, the work involved is trivial. When I'm flying, I suspect it will be somewhat more complicated.
