I have flown with it since they wrote the code, and have watched and compared with with our "sensed" AS AoA Pro system in the same airplane. It is stable and accurate in "normal" flight, in the pattern, etc. Useless in aerobatic, high rate maneuvers though - just not fast enough.
The problem that it shares with ALL of the EFIS-displayed AoA's is that you simply don't see it on approach because it is down on the panel - and you're not looking there during a base to final turn. No matter who's system you have, you need a glareshield display and/or an audio component to make it useful.
