runstrong92
Member
I?ve installed the EchoUAT with the SkyFX external antenna in my 4 but am having trouble getting it to talk to my SportEx. The suggested settings in the Echo manual are for installing using the GRT serial port combiner.
Does anyone with a similar setup mind passing along what you set your serial input/output sources to in order to get the Echo and the EFIS to talk? Thanks in advance!
