No rpm indication from my GRT 4000 EIS. Settings for RPM are all set and correct but no rpm showing at all. Running 2 Slicks on Lyc 4. I suspect it is a wiring problem although it all appears correct. Anyone have experience ref how specifcally wires should all run and how to trouble shoot to find problem?.
Google EIS 4000 manual. It’s all in there. You’ll need some 27k resistors if I remember correctly, connected from the EIS to the mag switch p leads..
+1
In some cases experimentation is required on the resistor size in order to make it work.
