Stockmanreef
should the grounding blocks be placed on the firewall near the battery ground? Or can they be placed on the sub panel? Also, should one put penetrox of Noalox on the connections to the firewall or sub panel?
If that wire carries starter current, then it should be as big as the starter positive wire. Otherwise, it should be as big as the main power bus feeder.What gauge wire should connect the forest of wires to the battery ground?
Not a stupid idea. It shows ingenuity.Does this make any sense? Or is it a stupid idea?
Bill--
what is that piece of green material that lines the lightning hole in the picture? I would like to line a couple of lightning holes in the bulkheads.
thanks
thanks. This clears things up for the ground. What gauge wire should connect the forest of wires to the battery ground?
Now I just have to figure out how the heck to attach the G3X shunt. It appears that it is connected to the master relay via a piece of copper, then, the two terminals connect to.....
