Gretz Audio Mixer pinout
Here you go,
The pin out for the Gretz mixer
pin 1 is 12V +
pins 2 - 10 is for audio inputs
pins 11 - 13 are not used
pin 14 Audio out HI
pin 15 Audio out Lo
pins 16 - 25 12v - Ground
How happy are you with the mixer? I’m worried about the mono part of it considering my intercom is a stereo one. Also, have you installed an external switch to, for example, mute a nav radio?
Thanks!
It works great for me. It's low cost, but you give up stereo through the mixer. If you have an extra audio input directly into your intercom, you could input stereo this way. I have not installed an external switch, but you could.
