mickey,
TIS is proprietary to the u.s. and already being phased out again before it has really caught on. the newest radar antenna replacements don't support it any more. the concept behind is, that the antenna uplinks/broadcasts a complete traffic picture, which receivers can make of whatever they want. however, this is always based on the location / coverage of an antenna.
ads-b on the other hand is beyond mode-s elementary surveillance. elementary surveillance is what is already or is going to be mandatory all over europe. a lot of light aircraft won't support ads-b for quite a while. not all aircraft have glass/navigation displays, neither do they all have at least an accurate gps or even ins/irs. some mode-s transponders don't even support the expansion to ads-b.
however think of the advanced mode-s transponder as the "wifi network card", enabling ads-b and allowing datalink services.
also, ads-b is only in part the technology of seeing all other traffic in the cockpit and transmitting it's own position. it covers also rules and regulations, wheter aircraft will be able to "self separate" etc... for ads-b there won't be a radar antenna required, at least in theory. but i don't see that happening in busy airspace anytime soon.
some of the primary gains from mode-s elementary surveillance and why it's becoming mandatory are:
-25ft altitude resolution instead of 100ft, allowing for much more accurate tcas and minimum safe altitude warning predictions.
-positive identification of all aircraft
-selective interrogation of aircraft, resulting in more tracking capacity of the antennas / especially in zones with multiple radar antenna coverage and allowing "aircraft 2 aircraft" communication (e.g. tcas resolution advisory, etc..).
a lot of airliners already put out their position as part of their ads-b / advanced mode-s data packets, which can be made to display on a computer.
there are boxes that you can buy for less than 1000€ and hook up to your pc, basically mode-s "scanners".
so an efis with the right mode-s transponder could be made to display that traffic. there are several limitations to such a solution however.
-as far as i know, the most popular mode-s transponder, the garmin gtx-330 does not support several of these datalinkg/advanced features as it is already an older unit.
-it doesn't help much if you can see the airliners at level 330 but no the vfr traffic in close proximity which you would like to see.
-submitting your own position will likely only be approved via certified units, as an accurate "own position" is critical for the complete system to work eventually.
-the whole thing was drafted pre 9/11, security/privacy issues are obvious.
so for now, the only real options are the zaon, true tcas units or flarm in europe, all having their pluses and minuses what performance, price and information quality are concerned.
bernie
p.s. with the latest software release on our radars, we're now able to see the mode-s info of all aircraft in our coverage area, so unauthorized penetrations of our class c airspace are now much easier to track and investigate than ever before.
