I am having a hard time deciding how to set up the pages so that they are easy to interpret due to not having data labels.
Anyone care to show the configuration you like?
Quite the indicator of how far some of the industry has come in the last couple of decades.
Exactly! Changing to something else since this is already operating does not interest meQuite the indicator of how far some of the industry has come in the last couple of decades.
If I were in the design phase....this is already running on a minimalist type installation. I am only trying to use it as built.Leave the display set up as a fuel totalizer, and put the rest on an EFIS page.
If you don't like the way it looks (IMHO it does look outdated) you can remote mount it and feed the data to a GRT EFIS, and then you have a modern system.
If you cannot afford an EFIS, or want a stand-alone backup, it does the job. Personally I like that big red light that comes on if there's no oil pressure.
Currently thinking.
Top line - RPM/MAP Oil temp/pressure
Bottom line - FuelL/FuelR Fuel flow Hottest CHT
