Stockmanreef
For people using garmin. How do you set your flaps? "Absolute position mode" or "relative position mode". the latter can have airspeed constraints.
If you have GAD 27, you can set it to relative position mode and then go to Engine page to set/calibrate it to set it at different position/degrees. Then pressing the flap switch, it will take it to the next position and stops.For people using garmin. How do you set your flaps? "Absolute position mode" or "relative position mode". the latter can have airspeed constraints.
That is correct, you need a position sensor which VANS sells or you can buy it direct from Ray Allen. VANS part is a kit which makes it easier and probably for the same price.The GAD27 just accepts a flap position input, correct? You still need a sensor to tell it where they are..I think.
