kentb
I have noticed as I play around with the Seattle Avionics Voyager flight planner that the world is not flat.
I entered a flight plan from KPDX (PORTLAND, OR) to KMLS (FRANK WILEY FIELD, MT) and scale to map so that I can see the entire route. When you grab the map and slide it sideways you can detect that the earth is not flat.
It is also noticeable that the path is not a straight line.
I know that the shortest distance between two point is often a curved line when plotted on the earth surface, but I usually don't fly far between landings and so don't notice this often.
Now the point of my post, could one of you high powered CFIs remind me (I am sure that I at one point I knew this), the NavLog notes that the Meg Hdg is 56 degrees, if I plug KHLN into my GPS (430), will it show me 56 degrees all the way to KHLN? Assuming that my AP is flying and keeping dead on course.
Kent
Kent
