I have a Synergy built E-LSA thats 8 months old with 91hrs. I removed the ACT406 ELT and returned for inspection as it's activated multiple times. After removal, my first flight 4 minutes after departure gps shut down message (position source 1 fail no adsb out gps lost) blank screen red x. After landind i called Dynon, turned on master gps map screen appeared, they took the time to have me check no conf changes, all good. Short flight today everything up and running but with timer set 3 minutes after departure gps failed again. Is it possible the removal of elt has anything to do with this failure?
Thanks Rod
Thanks Rod
