Av8torTom
I'm not getting ADSB in or out in my Garmin G3X set-up. (GPS-20A and GDL 50R)
Looking at the GPS-20A, I see the Unit status LED flashing fast green, but the GPS status LED is not lit at all.
I understand that some GA-35 antennas were defective - I need to look into that.
I will also check the antenna cable.
I would not expect this to affect ADBS in though, right?
If you aren't getting a GPS fix (solution, whatever..) then ADSB isn't going to work.
Well this is a little embarrassing. There was nothing wrong with any of the hardware, just the G3X and transponder RS232 ports were not configured properly.
Everything is working properly now.
