It's brand spankin new, better be freeGarmin normally flat rates repairs. Good luck!
Operating normally, in system setup everything is filled out, no missing info.I've encountered a few issues with Spruce harnesses, IMO the most likely problem is with the config module if the unit operates normally, either wiring or the module was fried from static discharge.
Not that Im aware of on that unit.Operating normally, in system setup everything is filled out, no missing info.
Is there a way to see if the config module is fried?
Totally agree with this and have seen this issue multiple times, the lower rack ‘lip’ needs to be flush with the outer edge of the panel.I had a similar issue, it ended up being my tray was slightly recessed on my the panel, I had to slide the tray forward about a 16th of an inch and the problem went away.
(or the panel cutout must be large enough for the faceplate to fit thru.)
I'll loosen up the bolts in the rack and see if I can get er in furtherNot that Im aware of on that unit.
