fstringham7a
Does anyone out there know if the GNS 430w has an internal diplexer so the VOR/Glide Slope can share the same antenna?
Frank @ SGU RV7A
Frank @ SGU RV7A
NO, it does not. The 480 does but for the 430/530/w you will need a external splitter or a separate antenna for the VOR/ILS.fstringham7a said:Does anyone out there know if the GNS 430w has an internal diplexer so the VOR/Glide Slope can share the same antenna?
Frank @ SGU RV7A
w1curtis said:NO, it does not. The 480 does but for the 430/530/w you will need a external splitter or a separate antenna for the VOR/ILS.
fstringham7a said:By the way where did you come by this knowledge?
Ironflight said:Look at the back of the unit....it has a G/S antenna connector and a VOR/LOC antenna connector.....![]()
Paul
