Mainly a question for the Garmin guys:
I have a GNC 250XL GPS/COM that is long past being supported. I would like to replace it with a modern unit and the GPS 175 will fit in the same slot. But I don't want to lose my 2nd COM capability. (Primary is an SL-30.) If Garmin can add a complete ADS-B compatible transponder to the back of the GPS 175, then
Does Garmin have plans to make a 250 replacement, i.e a GPS 275 GPS/COM in this form factor?
For sure I'd buy one
and I think a lot of other 250XL owners would also! Even better if it were rack compatible, slide-out/slide in!
Andy Elliott
Andy Elliott
