Does anyone know if you can mount a GMU-11 "upside down?" ..if all other installation limits are respected?
Also -- if the yaw axis and pitch axis are fixed properly during installation (limits as per the manual) -- is there any limitation as to the roll axis of the unit when installed ? i.e. must it be installed level in roll if the connector is oriented either forward or aft?
