Final queries before I glue my canopy?
I have resurected this thread because it is mostly from people who have used Sikaflex or have a positive interest in it. I hope it stays that way. There is another current thread for the doom mongers.
I have read most of the stuff that has been posted, but before I go ahead I have a couple of queries that I would welcome comment on, from people who have done this:
1. I plan to put the main 'fixing' coat all the way around, except for some 4" long spaces where the hose spacers/clamps will be. My question, when I come back to do these 4" sections after the thing is attached to the frame, will it be practical to get the primer into the 3/16" gap between the glass and frame? I guess this is a question of how runny it is.
2. I plan to do the 'cosmetic' coat at the same time I complete these 4" gaps. Is it appropriate to prime the cured Sikaflex when I add a cosmetic coat, or does it bond to itself just fine?
3. I am wrestling with which way up to do it. (The canopy, not me!) Because the -4 canopy is a one piece, I can not reach in through the end. I will have to set it between two stands quite high, so I can walk in from underneath. I presume to get a good finish on the visible / upper joint, it needs to be the right way up? Gravity will presumably not help the lower surface? I guess I am asking how much it oozes?
4. On the -4 canopy there is normally, a very small fiberglass fairing. Once Sikaflex is cured can it be sanded and shaped? I think I have seen a picture of this somewhaer but cant now find it. Is it suitable as a replacement for the glass? It will of course get painted.
Thanks so much.
