To make them stronger, on ours I added a layer of carbon fiber inside and outside....The tabs on my fairings broke off, so I lubed up the gear legs and laid some fiberglass on so it is curved to the gear leg. With luck, these new tabs will last longer.
Same here. My gear leg fairings just float inside of the intersection fairings.Mine don't have any clamps, just the hinges on the trailing edge and fitting inside the intersection fairings.
Hans
