H HSANTIBANEZ Well Known Member Jun 19, 2014 #1 Hi, what is the name of the gdl39 cable "connector" only? Regards
bhester Well Known Member Patron Jun 19, 2014 #2 Check here! http://www.aircraftspruce.com/catalog/avpages/gdl39.php?clickkey=1544767 Are you talking about the bare wire connector?
H HSANTIBANEZ Well Known Member Jun 19, 2014 #3 Yes that is the complete wire. I only need the male connector name. I whant to make a custom male female extension thanks For example the antena is a SMA connector.
boomer Well Known Member Jun 19, 2014 #4 HSANTIBANEZ said: Hi, what is the name of the gdl39 cable "connector" only? Click to expand... I think you're looking for "bare wire." -John
bhester Well Known Member Patron Jun 19, 2014 #5 Don't think you can get that I think others have tried to find that with no luck.
bullojm1 Well Known Member Jun 19, 2014 #6 I reverse engineered the connector. All of the details are here including pinouts and part numbers: http://rvplane.com/?categoryid=10000&dayid=1154
PerfTech Well Known Member Jun 23, 2014 #8 Cable!!!!! ....Here is the item; Part # 11-10735 This is available from Spruce and most pilot shops as well as from Garmin. Thanks, Allan.....
H HSANTIBANEZ Well Known Member Jun 23, 2014 #9 The cable no Hi thanks but i dont need the cable. I only need the connector name and i got it Regards,
