Had an interesting situation with the GDL39 and XM weather and 796 today, flying in Oklahoma the 796 showed a solid GPS signal but the XM signal showed full green bars for a few seconds and then dropped to two red bars then the signal disappeared for a second. This cycle repeated for the entire first leg of the flight and I never received XM weather, tried cycling the power on the XM antenna and checked the music which played when the bars were green then stopped when the signal dropped. I assumed it was a XM problem.
The XM antenna is on the glareshield and was about 6 inches from the GDL39 unit which is also currently on the glareshield on the passenger side. On the flight back I had the same problem and wondered if there was interference from the GDL39 antenna so I switched the GDL39 off and lo and behold the XM signal showed full strength and the XM weather showed up a few minutes later. Any one else experienced this? I am planning to eventually remote the GDL39 but am wondering how far apart the two antennas should be to work in the meantime, looks like the maximum I can get on the glareshield is about 12 inches.
Not a big deal right now as we do not have coverage in OK until next year but would like to understand if this is interference as I have plans to move the 796 and GDL39 between two aircraft in the future.
Comments?
Comments?
