Matt, thanks for the great support , you guys updated my 796 at the show. Does the gdl need a update ?
Select "NMEA Out" for the #1 serial port format and "Garmin Data Transfer" for the #2 serial port format. Don't forget to update your aera 796 software first.
- Matt
Matt, I thought someone in the Garmin tent told me that the GDL had to use serial port 1 ?
How do you change which weather you are using on the 796?
Hello David,
Reference Appendix D in the aera 795/796 Pilot's Guide and pages 3-5 & 3-6 in the GDL 39 User's Guide. For this type of application you can connect the two units as follows:
- TX1 wire (blue) on aera 796 to GDL 39 RxA wire (white/green)
- RX1 wire (yellow) on aera 796 to GDL 39 TxA wire (green)
- TX2 wire (orange) on aera 796 to third-party NMEA device
- RX2 wire (purple) on aera 796 - no connection
Select "Garmin Data Transfer" for the #1 serial port format and "NMEA Out" for the #2 serial port format. Don't forget to update your aera 796 software first.
- Matt
Have the software updates changed this, or is it still essential to put the GDL 39 on Aera 795 serial port 1 and use port 2 for A/P?
I am headed to the hangar tomorrow to hard wire the GDL 39 3D to the 795 with bare wire cable, and cannot recall if I already have the autopilot connected to TX1 or TX2. Easy enough to move it over, but don't want to if I don't have to.
Thanks!
Thanks Matt for the info ...Hello David,
- Matt
does that apply to GARMIN GDL50 with bare wire connection to aera 796
