Looking for a little assistance in leveraging the GDL-39.
I intend to use a GDL-39 with my G3X setup. I am hoping to mount the 39 under the seat and direct wire into 12VDC.
Will the unit power up automatically once it sees 12V without having to press the on button?
I believe this has a GPS in it, but I have several other GPS sources and don't need the GPS data. Will the 39 work properly if it cannot get a lock on a GPS signal, assuming the G3X has a valid signal?
Will I find a need to access the on / off button to reset the unit for blue tooth pairing problems?
Thanks for your assistance.
Larry
Larry
