I built an RV-3a in the early 90s, but It was a partially built kit, originally sold in the late 70s. I still have the original instruction book (20 pages), the original plans and receipts from various items we bought from Vans and other places such as Aircraft Spruce. Our plane used the taper pins for the wing joiner. The instruction book calls for AN386-3-15 taper pins. It also calls for using a B&B No. 3 Taper Reamer for reaming the holes in the spar and splice plates. I have a receipt for the No. 3 Taper Reamer ordered from Aircraft Spruce, and that worked well. I believe you can get these items from Aircraft Spruce. I also found a receipt for some AN975-4 Taper Pin washers. I don't remember if those were used on the wing or not but there are some special thick washers required on the threaded end of the taper pins before you can put on regular washers and nuts. The nuts were castellated and used cotter pins.anyone have part number/vendor for the old fuselage tank's gas cap? and spar taper pin p/n? AN386? van's indicated they have no data for either part.
