ccarter
I received a flyer in the mail from Garmin yesterday notifying of a free software update for the XM weather users. Apparently there is a software bug in the Garmin OS (operating system) for selected units (such as 396/496) which can prevent the unit from receiving weather data. The patch apparently is applied when you update the unit software using the updater provided free of charge from Garmin. The link is located here -> http://www.garmin.com/xm. Follow the links.
I would suspect you will need to have your XM antenna plugged into the unit when doing this update.
This problem sounds strangely like the random complaints we've all had with the xm weather intermittently dropping out on occasion. It's rarely happened to me but once or twice and then for only a minute or two. Others have had a more serious manifestation. As a software designer by vocation I suspect this has been a difficult bug for them to catch in the act and thus provide a fix. Hopefully, now that they've admitted it this will solve the problem.
I am going to apply the fix next time I bring the unit back from the hanger. For those of you that may have had a more pronounced problem with this it would be nice to hear if the update fixes it for you.
