jtsmith
Member
Hello;
I purchased a prewired Garmin SL40 tray that has the following (5) wire desiginations that I think are intended to interface with the intercom: 1. mike key, mike audio L., mike audio Hi, phone audio L., phone audio Hi.
The wiring harness purchased from Van's for the FlightCom 403mc has has the following (3) wire desiginations for the interface with the com: mike key, mike audio and phone audio.
The question is: Which Garmin mike and phone audio wires should connect to the intercom mike and phone audio and to what should the additional wires be connected?
Audio
Just connect the SL-40 audio hi, mic hi and mic key lines to the harness from the intercom. You can leave the audio low lines disconnected or run them to ground. Hope this helps.
Freddy
Freddy;
Thank you! Your reply came in less that five minutes from the time the post was made.
FANTASTIC
Jearld
