Good morning!
I'm connecting my engine sensors. My setup is: RV7A, 2 G3X touch displays, standard Van's IO360 M1B. The firewall forward kit comes with the Garmin sensor kit. There are 2 Kavlico sensors included in the kit which connect to the VA 168 transducer manifold. REF: construction drawing OP 27. Oil pressure and manifold pressure. A fuel pressure sensor is not included in the kit. The VA-168 transducer manifold has 3 ports. Do I need fuel pressure or is fuel flow through the kit included "Red Cube" sufficient for my setup?
Thanks!
SteveL
Thanks!
SteveL
