From your picture it appears that you have several more threads exposed on the opposite bearing than the one connected to the servo. Consider turning the push rod around or readjust the bearings so that they are at more even depths.
Also, is this wing attached and rigged to the stick? If it isn't fully rigged yet, you may just be going beyond the aileron stops.
